Helllo,
Thanks for looking, my problem may be simple - but it has been driving me crazy! I want to select an object based on its element ID (Object ID). I have tried a group and a line and i5 doesn't select the object. I have even tried SELECT IF. As a last ersort I used tool on the main toolbar, edit menu -> Select... and nothing is selected.
When I find an element ID using ISM (el.element_id) it returns the number (not the "AUTOID_") so I have also tried only the number part. If you look at the 7.1 Macro Language Reference documentation, page 64 I have followed the examples, even changing some wording around, just encase a typo exist in the documentation.
Has anyone had a similar problem and found a solution?
Many thanks
Alan
I just tried what you were attempting and did have a little trouble at first. Didn't seem to work immediately. Not sure if I had something set wrong or now.
Unfortunately/fortunately it did start working and I can't reproduce the initial problem. Now I can get both methods below to work without issue.
Select if Object_id is equal to 'AUTOID_34169'
and
Select if Object_id contains '34169'
Note that I'm running 7.2, build M020.
Hello Alan,
It should be a closed element like. eg: a rectangle.
Then only you can select using object ID.
Thanks & Regard
Vaduga
