Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
Hi, Can someone point me in the direction of the preference setting to save your XML files from Editor clean, i.e. without CF+LF+tabs so its just the raw XML. It is easy in XMLSpy, but I cant see what i'm looking for in prefs/advanced. Any pointers how apreciated. Thanks!
Hi, Chris... I think setting the "outputrecordlength" preference to "infinity" should get you what you want (or closer to it, anyway). Depending on your results, you may also want to try setting "writenobreaktag" to "on". -Brandon
