Saving clean XML from Editor
ChrisWestern
Hi, Can someone point me in the direction of the preference setting to save your XML files from Editor clean, i.e. without CF+LF+tabs so its just the raw XML. It is easy in XMLSpy, but I cant see what i'm looking for in prefs/advanced. Any pointers how apreciated. Thanks!
Hi, Chris... I think setting the "outputrecordlength" preference to "infinity" should get you what you want (or closer to it, anyway). Depending on your results, you may also want to try setting "writenobreaktag" to "on". -Brandon
Thanks Brandon, i will try these 2. Chris
