Hello, i am creating a Toc in docbook arbortext v8.2. My docbook tree is as follows below image. i want the toc for chapter here, which is section/section/chapter. the problem is, i can create Toc, but i can't restrict its scope to be inside of section/section only. The aumatically generated Toc is showing the Next chapter contents also if i give scope as chapter or section. here my chapter definately should come inside of part and a volume overall. i need to add scope of section/section for creation of Toc so i will get the result i want. is there any way to add like that?
If I read your information correctly you are looking for information on how to have a toc per chapter. Here is some info that looks like it might be close to what you are requesting. https://support.ptc.com/help/arbortext/r8.1.2.0/en/index.html#page/styler/styler/help31061.html
Bryon
Hello @Ramu_P,
It looks like you have a response from a community member. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
