Hello all,
We have a testingmemberswho uses SharePoint to store some test XML files. Our default XML editor is ArborText and it is configured to open any XML file (default application). However when I checkout a file from SharePoint it does not open the XML file for editing. Also when ArborText is closed and if I checkout the file, then ArborText application is opened but it does not open the file. I am getting a message that the file does not exist.
Is there a way to make ArborText to edit files from SharePoint? If not then I might have to move XML files to a directory of some network location.
Karthik
Thanks for the response.
Ed: In the SharePoint, I currently get "Edit Document" and I have changed my system preferences to open ArborText for any XML file. So it indeed opens up the ArborText but it does not open the file.
Jarrett: I had experienced the same issue. Try changing your file type under control panel>Folder Option>File Types. Navigate to XML and click "Change". Select ArborText. This should help.
Karthik
