Show Object in Window Suddenly No Longer Available
RaySnyder
We are importing fairly complex Pro/E drawings into IsoDraw (v7) then using IsoDraw to generate technical illustrations for manuals. We've started experiencing the following problem. Using the improted Pro/E file, an illustrator will right-click on an object to display the pop-up menu. Then "Show in Object Window" is clicked and the Object Window displays the objects list with the selected object highlighted. Next, the illustrator clicks on the "eye" to hide the object and reveal what is underneath. After a while working with the imported image, the "correct" pop-up menu will no longer display. Now the pop-up menu you normally get when right-clicking on the background appears instead. The illustrator basically hits a deadend with no way to continue. Saving, closing, then re-opening the file only makes things worse and the objects shift and are no longer aligned as they were in the original import. Any thoughts?
Did you dry doing this on another PC? Maybe the one with more RAM and/or video memory.
