Slow startup after reboot
olivier.colliou
Hi adepters,
I am using Editor 5.3 M030 under XPsp2 and Iam experiencing slow
startup time after PC reboot:
- after reboot: 130s
- others (even immediately after logout/login) : 10s
5.2 M030 was a lot faster.
Is it normal ? is there a way to improve that ?
Olivier.
World Intellectual Property Organization Disclaimer:
This electronic message may contain privileged, confidential and
copyright protected information. If you have received this e-mail
by mistake, please immediately notify the sender and delete this
e-mail and all its attachments. Please ensure all e-mail attachments
are scanned for viruses prior to opening or using.
5 REPLIES 5
Hi Olivier,
I haven't noticed any differences with respect to Editor startup time or
reboot time. I just upgraded from 5.2m020 to 5.3m030 yesterday.
If I notice anything wonky during testing, I'll let you know.
J
"Olivier Collioud" <olivier.collioud@wipo.int>
08/21/2007 01:46 AM
Please respond to
To
cc
Subject
[adepters] - Slow startup after reboot
Hi adepters,
Olivier.
Greetings,
It may be possible that some options may have been set that are slowing
down startup times. You can go to the Help->About Arbortext Editor->Session
and see what may have been installed that you weren't expecting. I noticed
on mine, that even though I turned off some things in the install, it still
tells me that there are some pieces installed.
The 'feature.cf' file is the place where those are turned on/off if you
need to change anything.
Could be a piece to the puzzle.
Thanks.
David Helfinstine
IBM Rochester, MN
Tele: 507.253.5143
[ David_Helfinstine@us.ibm.com ]
"Jason Aiken"
<jason.aiken@jepp <br="/> esen.com> To
08/21/2007 08:57 cc
AM
Subject
[adepters] - RE: Slow startup after
Please respond to reboot
adepters@lists.pt
cuser.org
Hi Olivier,
J
08/21/2007 01:46 AM
Please respond to
To
cc
Subject
Hi adepters,
Olivier.
Just a guess, but sometimes when things are terribly slow
for me, especially just after a reboot, it turns out to
be that the system is trying to access some network
drives that it expected to be mounted but weren't, and
it takes a fair amount of time for it to try to open/mount
a drive before it either mounts it or gives up. If it's
looking for several such drives, it could take minutes
trying to find all of these.
As far as why bringing up Epic would cause it to look
for external drives, I couldn't say, but you might look
in that direction as you investigate.
paul
Could your problem be related to an anti-virus scan?
I have a client whose anti-virus scanner would scan all the jar files in the Epic install path every time a user first launched Epic. It slowed Epic's launch down enormously until I had them exclude the Epic install path from their virus scanner. When testing new versions of Epic on their network they have a recurrence of the problem because the install path used for the new version is different from the standard install path and therefore not excluded by the virus scanner.
Cheers,
Dugald
Thank you all,
The anti-virus seems to be the culprit.
Olive.
