I used the Table of Contents objects to build a Table of Contents for HTML Help.
However, I can't seem to customize or format the Table of Contents object. When I select the Add... button in the Customize Table of Contents window, there's even a note that changes will not effect my Table of Contents.
So how can I customize my Table of Contents object for HTML Help? I cannot use a basic formal block/title object model to create my Table of Contents.
To start, I have to combine two elements to create a work package title - hardware name and maintenance action (like combining "Rear Wheel" with "Remove").
-James
Never mind, I found a work around to my specific issue.
