Spanning causes introduces colsep
ptc-3063012
In Arbortext when I try to span 2 cells in a table my entry gets a attribute colsep="1". I don't need colsep attribute to be inserted when I span 2 cells. Is there a way to turn this off?
Karthik
On Wed, Mar 10, 2010 at 4:04 PM, Karthik Kumar
Can you post an example (preferably a small one) of the markup before
and after and the exact steps you took in between? Also, what DTD are
you using (or the table model, anyway), and which version of Editor?
-Brandon 🙂
Hello Brandon,
ArborText version is 5.3 and I tried it in our DTD that uses CALS table model. I also tried it on DocBook DTD and the sample attached uses docbook DTD.
You will notice 2 tables - the first one without cell span and the next one with cells span.
Before spanning
<tgroup cols="2">
<colspec colname="col1"/">
<colspec colname="col2"/">
<tbody>
<row>
<entry>Cell 1</entry>
<entry>Cell 2</entry>
</row>
<row>
<entry>Cell 3</entry>
<entry>Cell 4</entry>
</row>
</tbody>
</tgroup>
After the spanning it markup changes like:
<tgroup cols="2">
<tbody>
<row>
<entry colsep="1" nameend="col2" namest="col1"&lt;br"/>>Cell 1</entry>
</row>
<row>
<entry colsep="1" nameend="col2" namest="col1"&lt;br"/>>Cell 3</entry>
</row>
</tbody>
</tgroup>
Karthik
Hi, Karthik...
On Thu, Mar 11, 2010 at 10:40 AM, Karthik Kumar
> DTD.
> with cells span.
I tried this with both Arbortext Editor 5.3 M120 and 5.4 M010, with
identical results. I created a new Docbook document and added a
2-row, 2-column table, filling in the content you had in your example
such that the markup looked identical to your "before" case.
> Before spanning
> <tgroup cols="2">
> <tbody>
> <row>
> </row>
> <row>
> </row>
> </tbody>
> </tgroup>
I then spanned the cells in the first row using the "Table", "Span
Cells" menu item. After that, I spanned the cells in the second row
using the Alt+F11 keyboard shortcut. In both versions of Editor, the
resulting markup was:
<tgroup cols="2">
<tbody>
<row>
<entry nameend="col2" namest="col1">Cell 1 Cell 2</entry>
</row>
<row>
<entry nameend="col2" namest="col1">Cell 3 Cell 4</entry>
</row>
</tbody>
</tgroup>
> <tgroup cols="2">
> <tbody>
> <row>
> <entry colsep="1" nameend="col2" namest="col1"&lt;br"/>>>Cell 1</entry>
> </row>
> <row>
> <entry colsep="1" nameend="col2" namest="col1"&lt;br"/>>>Cell 3</entry>
> </row>
> </tbody>
> </tgroup>
Note that my markup does not include the "colsep" attributes and that
it also includes all of the content of the two cells that were
spanned, where yours includes only the content of the first cell. In
order to figure out why you're seeing this behavior, we need to
eliminate the differences between our cases.
Which patch level (M???) of 5.3 are you on? Can you give me more
detailed steps that I need to follow to produce this result? Could
there be any preference settings in your environment that might be
affecting the results?
-Brandon 🙂
Thank you so much Brandon for trying this. Both of us did exactly the same thing and we are seeing different result.
I found one thing today - When I spanned the cell on AT 5.3 M010 it puts colsep. However when I tried it os AT 5.4 it does not put colsep. May be this is because of the patch.
Karthik
Yes, if you're seeing this on 5.3 M010, I'd definitely try a newer
release before putting any more effort into tracking it down. There
have been 16 releases of 5.3 since M010 (and 4 of version 5.4), so
it's quite likely that what you're seeing is a bug that has since been
fixed.
-Brandon 🙂
On Fri, Mar 12, 2010 at 2:38 PM, Karthik Kumar
> Karthik
