Strange bug found in IsoDraw 7.1 M070 on Windows 7 64 bit
ptc-911904
FYI - IsoDraw 7.1 will crash when opening a CGM that was exported out of Team Center Visualization Mockup 2007 (64 bit). VisMockup can export CGM versions 1, 3, and 4. All versions will crash IsoDraw.
The crashes only happen when the Objects window is displayed. If the Objects window is turned off before opening the CGM, the CGM will open fine.
Attached is a sample CGM that causes this problem.
Dwayne,
This issue has been fixed in IsoDraw 7.2 F000.
Regards
Tim
