String functions in savetext or usetext?
cleccese
I want to check the first character of a #CONTENT savetext for a parenthesis "(" and if it exists, strip it out.
an xpath condition test starts-with(self::text(), '(') didn't work.
And these didn't work in a conrule:
substring(#CONTENT,2) or substr(#CONTENT,2)
Can you put an XPATH expression in a conrule?
(Styler 5.3)
Thanks!
Hi Caroline,
You can put XPath expressions in a savetext conrule or usetext source, as described in the attached xpath.pdf.
You can call ACL functions using SYSTEM-FUNC, as described in the attached system-func.pdf. In addition to the substr function, I think you'll need the match function.
Hope this helps!
Good luck!
Suzanne Napolon
www.FOSIexpert.com
"WYSIWYG is last-century technology!"
bibach
(To:cleccese)
Regarding the first part of your question, try "starts-with(., '(')",
instead.  The "self::text()" expression would only work if you were
evaluating the XPath in the context of a text node in your document,
which would never be the case in a FOSI, since an e-i-c can only match
elements or PIs.
-Brandon 🙂
On Mon, Mar 19, 2012 at 11:42 PM, Caroline Leccese
> (Styler 5.3)
> Thanks!
Thank you, Suzanne and Brandon!
