Styler 5.1 license
Highlighted
Newbie
Styler 5.1 license
System: Windows XP
Version: Epic 5.1 with Styler
Dear Adepters,
We have a single concurrent license of Styler that we plan to install on
our license server. We want to limit access to the Styler license. Is
this possible? I wasn't sure when the license got used. In the past when
we used Print Composer, we grayed out the Composer options on the
non-developer's menu.
Thank you in advance for your help.
Susan Ohara
JICPAC
Tags (2)
Highlighted
Re: Styler 5.1 license
I think that when you install Epic on individual PCs, that you can
either install Styler or not. If you don't want someone to have access
on their PC, don't install it. If you have communal PCs, then you would
need to do some profiling.
Highlighted
One way you can restrict the licenses is via the "resourceinfo" file on
the license server. In this file, you can restrict licenses to specific
users or groups. For Epic 5.1, Chapters 7 and 12 (Windows and Unix,
respectively) of the "Installation and Licensing Guide" describe how to
do this.
Brandon Ibach
Lockheed Martin Space Systems
Cocoa Beach, FL
321-784-7432
