On 9/25/07, Ketelsen, JR <jr.ketelsen@flatironssolutions.com> wrote:
> Hello;
> Is it possible to add a charfill using Styler. I can modify the FOSI
> source for an individual element, but can I get to the underlying FOSI.
> What I am trying to do is implement Suzanne's proposed solution to boxing
> using Styler.
> I can do this using the gentext tab, but I do not see where to supply the
> cfid
> Thank you,
I'm heads down on a deliverable (plus I'm a 5.2 m030 user) so I can't check
this out for you in 5.3 to be sure BUT you *may* need to / be able to define
the cfid by selecting Format / Edit FOSI Resource Description.
Paul Nagai
