Adepters:
We're using Styler for the authoring view (Epic 5.2 patch M080).
Sporadically, when I open a document I get this warning message:
[A28138] Stylesheet has references to missing definitions.
These references will be ignored. Use Styler's Validate Stylesheet menu
item to locate these errors.
Of course, when I do that Styler reports that there are no stylesheet
errors. Also, when I ask it to add new elements from the schema, none
are found. Every element in the schema is styled. What do I have to do
to get rid of this warning message? Is there some way to determine
where it's coming from or what triggers the message?
It wouldn't be so bad if I was the only one receiving this message, but
my users are reporting its occasional appearance.
Dave
