Styler: titles relocated, hidden gentext still shows in print view
steve5
Newbie
Here is a detailed procedure for relocating Table titles and numbers from
before the table to after (DocBook XML DTD). It works similarly for figure
titles.
It works as expected for edit view, but not for print view. For print view,
Epic+Styler fails to hide the text in the "title in table" element Gentext
tab's "Add before element content" field. (Same problem when outputting
to HTML)
Am I making a mistake somewhere in this procedure? Or, have I found a bug?
begin *****************************************************
It is necessary to keep the generated text and autonumber pairs so that
they appear in the List of Tables. However, you must hide them.
Tags (2)
