I use Outlook....anyway, the gentext is set to on. I noticed that when I make a change to the attribute in an element, the styler sheet does not reflect the change unless I do what I "described" or when I "Repeat Modify Attributes". We customize Epic with .NET.
There is no Repeat (last action) in ACL or in the AOM, or atleast I haven't found any so, I did this:
documentInterface.Undo
documentInterface.Redo
This works, but it seems a little hokey to me... thanks for your inputs. Aloha.
