Version:
Arbortext Editor 5.4 M110
Background:
Details:
Comments:
If someone could point me in the right direction it would be appreciated.
Thank you in advance
Try calling the stylesheet_revert() function after the FOSI is changed. That should reload the stylesheet from the disk file and bring in the changes.
--Clay
--Clay
Thank you, that did the trick! ![]()
