Tabbing in tables
Highlighted
Tabbing in tables
When you use the tab key in the edit window, you go from one field to the
next one except when you are in the last cell of a table. In this case,
tabbing will not go to the first element after the table but will add a new
line at the end of the table.
Is there a way to avoid this behaviour or a key combination to go from the
last cell of a table to the first element after the table?
Thanks a lot,
Benoît
Tags (2)
Highlighted
Re: Tabbing in tables
Pressing the down arrow will get your cursor just outside the table closing tag, but not actually inside the next element.
Highlighted
Hi Ed,
Thanks for this. Sometimes, for unkown reason, you don't even think to the
most simple solutions 😉 😉
Benoît
