Then I tested specifying the width for an authored table and leaving the column
widths proportional, and the table had the correct width in the Edit window, but
in Preview, it was margin to margin. As with the gentable, specifying the column
widths worked in the Edit window and in Preview.
Hopefully this is fixed in 5.4, which I don't have so I can't test it. If anyone
determines it is not fixed in 5.4, would you please do everyone a favor and
bugreport it to Arbortext technical support?
Thanks!
Suzanne Napoleon
www.FOSIexpert.com
"WYSIWYG is last-century technology!"
