The command to specifies the DCF file signal me an error
Highlighted
Newbie
Hi adepters,
I have develop a function in which I change the dcf file with the command
below
set dcffile = "instance.dcf"
It works the first time I go in the function
When I quit my function, I use it to restore the last dcf file ( I have
save it before).
But sometimes I get the message "epic: segment violation (signal11)" and
Epic Editor close.
I use Epic 4.3 under windows XP.
Issomebody already met the problem ?
Thanks for advance.
Cyril
Tags (2)
