Hi all,
Someone get the message [A17002]catalog file warning when open Arbortext Editor 6.0, only one machine. “Confirm”, then open AE normally.
For the demo.xml, the keywords "1.0" is separated.
the demo.xml is the following, when I delete the "1.0" (include " "), we can open AE normally.--------but the demo.xml is wrong, so we can't integrated the AE to CMS.
We can't find this problem before.
Could you give me any tips please?
Your assistance will be highly appreciated in this regard.
Thanking you
Hi Lorin,
Unfortunately, you may not be getting input on this as without the full syntax of the error, it's tough to pin down.
I haven't seen that error number anywhere before, so that's complicating things as well.
It may help if you paste in a few lines from the catalog or dtd that are relevant, see what the Editor is looking at.
Thanks!
Thank you, Rafael!
I will try it follow your suggestion!
