The problem about paste table in office word for the customized DTD.
lxie1
Dear all,
I meet a confusing problem.
When I using the Arbortext default DTD, such as topic, concept, we can paste table in office word to the xml, and it can generate the <table>
automatically.
But I customized some DTD, and create the topic, when I paste table in office word, not only table, also text, the Arbortext Editor will promet "agettext: Msgid not found in message file: CopyPaste failed to convert clipboard". Every time paste...
After I changed the pastesource preference to mif;rtf;txt (delete the htm), it didn't promet "agettext: Msgid not found in message file: CopyPaste failed to convert clipboard" again, but still I can't paste table in office word to xml. it will generate the <p>.
Did I lost some setting, or steps, or some check for the DTD? Could you give me any tips please?
Thanks!
Sorry I'm not overly familiar with how to get this working but I do know that the "smart" copy/paste from MS Word uses the Arbortext Import/Export technology to do the MS Word to XML conversion. It sounds like you need to customise the Import/Export MapTemplate that is used for smart copy/paste to support your custom DTD.
Thank you Gareth, I will try to config and use the Arbortext Import/Export!
