Trapping of Events
Level 1
Trapping of Events
I have a situation where I want to trap the different mouse and key =
events.
In Adept we have doc_add_callback function which traps various events =
like create, destroy, table deletion, table creation.
I am able to trap these events but what exactly I want is :
When ever any of the keyboard key's are pressed or any mouse button is =
pressed, I would like to trap it and do some operation at this pt.
Any Idea how to do this?
thanks in advance
Anita Nagri
HCL Technologies India Private Limited
anitan@ggn.hcltech.com
Tags (2)
10 REPLIES 10
Trapping of Events
-----Original Message-----
To: Adepters
Date: Wednesday, July 07, 1999 5:13 PM
Subject: Trapping of Events
events.
thanks in advance
Anita Nagri
Trapping of Events
Anita,
You want to use the "map" command.
Write "help map" on the command line (which you can activate
by selecting "Preferences" from the "Options" menu,
then select the "Window" tab and make sure
the "Command Line" option is marked).
/ Svante Kleist - NEMESIS systemDesign, Stockholm, Sweden
Trapping of Events
Svante,
This is not actually what I need. Let me explain you
Whenver the caret moves inside a table by any of key's or key
combinations and by the mouse click .
I would like to trap this event (i.e I want to be notified that the
caret is inside the table)
Similarly when the caret moves outside the table , I would like to
trace this event also.
for e.g In Adept editor whenever the cursor moves inside a table the
table rulers get's activated and when
it comes out of the table , the table rulers get de-activated.
But if we use the map command then we have to write the same code
for each and every key mappings or
key combinations , which is very tedious.
>Anita,
>--On den 7 juli 1999, 17:13 +0530 Anita Nagari
>> events. In Adept we have doc_add_callback function which traps various
>> events like create, destroy, table deletion, table creation. I am able
>> thanks in advance
>> Anita Nagri
Trapping of Events
Aha,
Something like this should do it:
Trapping of Events
Svante,
Many thanks, part of the code you put out here today filled in a blank spot
I needed for something I've been working off and on for a while. I knew
what I wanted, just couldn't get my limited ability with ACL to do it for me
til now.
Lynn E. Hales
Information Systems Specialist
AMSEC LLC
(757)688-9324
hales_le@nns.com
Trapping of Events
events.
thanks in advance
Anita Nagri
Trapping of Events
To: Adepters
events.
thanks in advance
Anita Nagri
Trapping of Events
Svante,
>Anita,
>> thanks in advance
>> Anita Nagri
Trapping of Events
Aha,
