Use XSLT 2.0 engine in Arbortext Editor or PE
longjingjun
According to Arbortext help, Saxon 6.5.3 which support XSLT 1.0 is used in Arbortext.
Does anyone know if I can use an XSLT 2.0 engine in Arbortext Editor and PE. If so, how I should replace/config in the system.
Thanks in advance
Jingjun
Paul,
Thanks a lot for the response.
Is there a way I can use XSLT 2.0 in Arbortext 5.3?
Jingjun
Hi JingJun--
You might be able to make this work by getting a newer version of Saxon (
<value> child element, set to com.icl.saxon.TransformerFactoryImpl by default. You can set this to
