Use XSLT 2.0 engine in Arbortext Editor or PE
JingjunLong
Hello, According to Arbortext help, Saxon 6.5.3 which support XSLT 1.0 is used in Arbortext. Does anyone know if I can use an XSLT 2.0 engine in Arbortext Editor and PE. If so, how I should replace/config in the system. Thanks in advance Jingjun
lfraley
6-Contributor
(To:JingjunLong)
This should be pretty thoroughly documented in the helpfiles.
I went looking in the Adepters archives, because I know this is a question that's been asked on the list in the past and that several folks who read/contribute to the list have done it. You might try asking this question there.
About the Adepters Mailing List:
The PTC/User portal (http://www.ptcuser.org) hosts the long-running Adepters mailing list. This list started in 1996 and has always been monitored by the PTC/Arbortext software engineering staff. Many long-time users and tools folks also regularly monitor the list. If you have a question, it's a really good resource as questions generally get answered within 24 hours. Beginning and advanced questions encouraged.
The List Email Address is: -
You can join the list from the PTC/User portal: http://portal.ptcuser.org/p/fo/si/topic=21
