I am using the ArborText Editor (v. 5.4) startup command to print my XML documents to PostScript files.This process uses our standard Editor FOSI. I would like touse certain FOSI features like"keeps" to control the breaking ofelements over page boundaries. Will this work using my Editor FOSI?
John
Yes, you can code Keeps in the FOSI. The Keeps category does not apply to the Edit window. One thing: in the tagged FOSI editor, select Edit->Stylesheet Identification and make sure Print/PDF is checked.
