Validation Automation
ptc-924238
Hi, part of my job is to validate lots of files in the shortest amount of time. I am usually dealing with thousands of files. So up until now I've been using AutoIT to "control" Epic. But when doing this, I have to shut down Epic completely for each file to clear up the memory, otherwise it gets too big quickly. I think I should be using an ACL script instead so I came up with; Edit -OK [filename];Check_completeness -Full output=[filename];file_close();wait 1 So what I do is create an ACL script with one line as above per file to validate. But then, I get into the same issue: the memory gets too big quickly, and Epic usually can only do 50-60 files before it gets too slow. I am using a recent Dell Precision (Quad6700) with 4 GB RAM. How do I modify this line so the memory clears up after each file closes?
Since it seems all you do is "checking for completeness", you could simply validate the XML against your DTD or Schema, using for instance a Xerces-J in Java or some .NET classes, it's just a few lines of code, or you might even find some precompiled validator.exe somewhere on the web.
Hi Lech, Thanks for your reply. I should have mentioned that I have to use Epic most of the time. This is a client requirement, and in most of the cases, given that their environment is usually highly customized, it also makes sense. I am aware of all the other possibilities out there to validate XML files. But I have to validate using Epic. I came up yesterday with a new way using Powershell -becuase it can act on processes-, but it's not what I want; I'd rather have a good ACL script.
