we currently have Arbortext Editor, Styler and Arbortext Publishing engine along with Documentum. We need to upgrade Documentum Environment to Content server 7.1 or 7.2 as well as upgrading to WebTop 6.8. Does PTC support those Environments?
What are the latest Documentum environments you support?
What are the latest versions of Arbortext Editor, Styler and Publishing Engine?
Editor 6.1 M060, which is currently in QA, is being tested for Windows 8.1 and Webtop 6.8. I'm not certain what Content server versions are supported, but based on previous support, it will be 6.5 and above:
http://support.ptc.com/WCMS/files/165306/en/Arbortext-Software-Compatibility-Matrices-6.1M050.pdf
6.1 M050 is the most recent version of all our products, and supports Webtop 6.7 and server 6.5 and above
Please be sure to note, after our 6.1 stream is completed, we will no longer provide ongoing support and maintenance for Documentum:
http://support.ptc.com/appserver/wcms/standards/freefull.jsp?&im_dbkey=163457&icg_dbkey=222
Thanks Rafael,
This information was helpful.
When you say that after your 6.1 stream is completed, you will no longer provide ongoing support and maintenance for Documentum.
Does it mean that ArborText Editor 6.2 (and beyond) would be seized from supporting Documentum Webtop and also you will stop maintenance service for the previous versions of Arbortext editor which is integrated with Documentum Webtop?
Is it possible for you to provide a screen shot from the Arbortext-Software-Compatibility-Matrices-6.1M050.pdf mentioning WebTop compatibility?
As I am having not having access to download the file.
Thanks for your support.
