I need to install Windows 8.1 for some other tasks. Will Arbortext 5.4 M030 work on Windows 8.1.
Shaylesh
5.4 Standard support ended in June 2013. It may work, but you'll be in an unsupported environment and PTC won't help you if you have problems. It may not matter since you're in an unsupported environment anyway what with still using 5.4 after EOL.
Product Calendar: http://www.ptc.com/cs/product_calendar/PTC_Product_Calendar.htm
