Chris,
See the topics under "Authoring", "Macro recorder" for details about how
the recorder is used and where the macros are stored.
The macro recorder stores your actions as a series of statements in the
Arbortext Command Language (ACL), which is the built-in scripting
language in which many of the built-in features of the editor are
implemented. ACL is not a difficult language to learn. The
documentation, primarily in the help file under "Arbortext Command
Language (ACL)", is quite good.
Given that the macro recorder will help you get started by recording a
reasonable series of ACL statements to do approximately what you want,
it should not be too hard to tweak the results. You can open the MCF
file in which the macro is stored in Arbortext Editor itself, as it is
an XML file. It shouldn't be too hard to see which ACL command is
executing the search, then look the command up in the help file index
for details about how you can modify it to do what you want.
Give it a shot and come on back with any specific ACL questions, if you
get stuck.
Brandon Ibach
Lockheed Martin Space Systems
Cape Canaveral, FL
321-476-7051
