accessing the replaced element from an embedded xui dialog on windowload
jsulak
Hello Adepters,
I've created an embedded xui dialog box that's a simple dropdown menu, and its purpose is to let the user set an attribute value on the replaced element.
When the dialog box is loaded, I want the dropdown to display the current value of the attribute. But I can't figure out how to access the replaced element from inside the WindowLoad event handler. I can access it from the domactivate event by using:
Application.event.view.window.ownerNode
But Application.event.view is undefined when I try to do that from the WindowLoad event.
Any pointers? This seems like it should be easy to do.
-James
tfu1
(To:jsulak)
Hi James,
Try Application.event.target.ownerNode.
In a WindowLoad handler, the Application.event.target is the window.
Tung
jsulak
(To:jsulak)
Thanks, Tung. That's exactly what I was looking for.
-James
Hi James--
Yes, you have to use a different approach to get the window handles
inside windowload as opposed to domactivate.
To get the dialog document (the XUI document underlying the dialog) in
windowload, I have to use this:
dlgdoc = Application.event.target.dialogView.document
So, it might work for you to do something along these lines:
docnode = Application.event.target.dialogView.window.ownerNode
HTH
--Clay
