I am tring to profile a procgroup. My current setup does not let me do this. I have contacted PTC support and they said that I need to add the ability to profile to a procgroup. When I click on the the profiles window and add a profile it says could not apply profile since the affected element does not support a "product" attribute. How do I correct this? Where do I need to look? Is it in stlyer or is that a setting that I need to modify in one of the .pcf files.
Thanks for the guidance Clay, I am probably in over my head on this one by a long shot. I have found two files servicemanul.dtd and smamap.dtd. Do I need to modify both or just one?
Thanks for the answer Clay. I was right way above me.
Bryon
Bryon
In Reply to David Helfinstine:
Hello again,
I don't know why I read 'procbody' as 'procgroup'. It depends on what element procbody is derived from. Most all DITA elements have the profiling attributes defined in them (in the dtd or schema). I still believe your issue is because you are within the element <textwrapper> you may need to move your cursor to get to the procgroup tag to be able to profile that.
Thanks.
- Dave H.
Dave Helfinstine
With some guidance from PTC Tech Support. I located the smaprocedure.mod file. I located the element declarations from there I found the ATTLIST procgroup, I added%select-atts; to the list. I am now able to profile procgroups. Thanks for all the help.
Is there anything I need to watch out for when testing this?
Bryon
