automatic scale parameter used by IsoDraw when exporting CGM to JPEG using IsoDraw macro ?
rhadjab
How to retrieve the automatic scale parameter used by IsoDraw when exporting CGM to JPEG using IsoDraw macro ?
thendricks
(To:rhadjab)
I'm assuming you're talking about resolution which you would use app.jpeg.resolution.
Example: 'message app.jpeg.resolution'
If you meant quality however it would be app.jpeg.quality.
Example: 'message app.jpeg.quality'
rhadjab
(To:thendricks)
Thank you for you response, what I mean it's :
I have a CGM file, and when I try manually to convert it to jpeg without insertion of parametters in IsoDraw, he show me this warning message " The size exceeds the maximum number of pixels".
Now, when I try in second time to export manually to JPG, I clique in option, now,  Isodraw calculate automatiocally the default scale of this file, and when I clique export, the exportation is doing succefully.
My question is  : how can I get this default scale when I using macro in IsoDraw ?
