changing SGML declaration
Level 1
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
I have a situation in which all of our tags are in upper case and
downstream tools depend on them being that way.
With Adept 8.0 it changes all the tags to lower case when it saves the
document. I'd like to avoid this if possible.
I tried editing the SGML declaration, but when I try to save it adept
just wants to write out a text file.
Any help on this would be *greatly* appreciated.
Kenneth D. Weinert
It's 106 ms to Chicago, we've got a full disk of GIFs, half a meg of
hypertext, it's dark, and we're wearing sunglasses. Click it.
(cribbed from Christopher Davis)
** Tag(s) inserted by Bandit Tagger98 - http://www.gbar.dtu.dk/~c918704
PGP Public Key Fingerprint: A81E E71D 34EE 5AF2 6CB1 D899 690C 5981
-----BEGIN PGP SIGNATURE-----
Version: PGPsdk version 1.0 (C) 1997 Pretty Good Privacy, Inc
iQA/AwUBN3uGI2kMWYH60NHeEQK9zACdEhd96hKfrmZgIvfqvbqRAKiP+ZoAoIdh
IDNyVYs4cs/+VbXBu7BIo1yI
=M+iJ
-----END PGP SIGNATURE-----
Tags (2)
Kenneth,
I'm not sure I fully grasp your situation, but are you
editing the SGML declaration with ADEPT? In that case,
ADEPT does the right thing since this file _is_ a text file
(i.e. it contains no markup).
I tend to edit the SGML declaration in my favourite text editor.
/ Svante Kleist - NEMESIS systemDesign, Stockholm, Sweden
In general, Adept reads the character representation of any valid SGML
file and produces a logically equivalent internal data structure on
which the editing process can occur. When Adept saves the file, it
traverses the current data structure and "serializes" it (i.e., produces
a character representation of it) as valid SGML. "Insignificant" details
of the input format are not represented in the internal data structure
and are therefore not represented in the saved file. Here, "insignificant"
is used in a technical sense to mean that, per the SGML standard, that
that data is not considered to be logically meaningful to the actual
information content. So, details of things like omitted tags, shortrefs,
omitted quotes around attribute values, and the details of whitespace
within markup are lost during a read/write cycle (this process of losing
insignificant data is often referred to as "normalization").
Whether element and attribute names are case sensitive or insensitive
is determined by the setting of the NAMECASE GENERAL feature in the
SGML Declaration. NAMECASE GENERAL YES means that element and attribute
names are case insensitive (i.e., case of those names is not significant)
whereas NAMECASE GENERAL NO would make the case of those names significant.
When case is not significant, Adept always writes out lower case. That
is, Adept's normalization process is to lowercase names where case is
insignificant. This is not something that can be changed.
Setting NAMECASE GENERAL NO in the SGML Declaration would say that the
case of all element and attribute names is significant. This would mean
that any tag entered in all uppercase would stay that way. But it would
also mean that you have to be completely consistent in the case you use,
since any name entered in a different case will not match (using a different
case when NAMECASE GENERAL NO is like spelling something differently--it's
a different name). This may or may not be what you really want.
Prior to the upcoming release of Adept, NAMECASE GENERAL NO is not
supported, so there is no easy answer using Adept 8.0 itself. The
best solution might be to run the resulting file through some other
process to uppercase all names you want uppercased. Note that any
downstream tool that is SGML-compliant wouldn't care, because case
is insignificant, but I realize there are many non-SGML tools that
are useful, so I understand your desire.
Note that XML--which doesn't support sgml declarations, so this
feature cannot be varied--always behaves as though the setting were
NAMECASE GENERAL NO. That is, case is always significant (and
therefore preserved) in XML.
paul
