columns, how to get them working
Newbie
I'm am not to proud on having to ask this, but how do I get my text into
columns?
sigh()
I defined a pageset called two columns. I defined the two columns the
gutter, all goes well.
On a certain element I have placed the text break start page =
next page-id - 2columns.
I'm thinking that this is all there is to it.
My mistake, nothing happens.
When I look at the pageset definition, I have the option of selecting the
number of columns I want to use. My guess was if I select two, I will get
my text in two columns...wrong again.
Each time I go there the first diamond (as the help file calls it), is
selected and not the one I want: 2 columns.
I'm obviously missing something fundamental here, just hoping one of you
can help me out.
RH
Tags (2)
Re: columns, how to get them working
At 15:40 2001 12 21 +0100, ronald heller wrote:
>how do I get my text into columns?
>I defined a pageset called two columns. I defined the two columns the gutter, all goes well.
>On a certain element I have placed the text break start page = next page-id - 2columns.
>When I look at the pageset definition, I have the option of selecting the number of columns I want to use. My guess was if I select two, I will get my text in two columns...wrong again.
>Each time I go there the first diamond (as the help file calls it), is selected and not the one I want: 2 columns.
In the eic of that element that does the textbrk to
start your two column mode, try adding:
paul
you need <column span="2"> for each e-i-c concerned
> columns?
> sigh()
> can help me out.
> RH
In the horizontal properties of your e-i-c, in addition to using the text
break start page, use
There is a charlist tag which can be
used within your <docdesc>'s charlist or
directly within you <e-i-c>'s charlist
Miriam Brady - - Title: Software Support
The Beacon Group - - Email: brady@beacon.com
1797 Seddon Court - - Tel: (419)289-0558 x132
Ashland OH 44805 - - Fax: (419)289-8923
> columns?
> sigh()
> can help me out.
> RH
Oops, I meant, in your e-i-c, in addition to the vertical text break start
page, add to the horizontal properties.
