curl character instead of space in Arbortext Editor 6.1 M020 or Styler
hbestler
Dear guys,
do you know an opportunity to get a 'curl' character like in WinWord instead of space character in Arbortext Editor?
In XML there is an three-per-em space unicode between this characters, like here:
As you can see there is only a space character visible.
In WinWord the useres know this sign:
As you can see there is a curl between the characters.
Is it in Arbortext Editor or Style also possible to get the curl instead of the space character?
Thank you in advance for your help.
Hubert
Is Insert -> Symbol (Einfügen -> Symbol) what you're looking for?
For autonumbering you can use Prefix/Suffix:
hbestler
(To:DmitryTsarev)
Hello Dmitry,
thank you for your answer. We dont need autnumbering prefix/suffix. There are many   spaces inside the xml file. We would like to show a curl instead of the space in the Arbortext Editor.
Ahh, OK. You should then just edit the <Arbortext>\lib\charent.cf file
hbestler
(To:DmitryTsarev)
Can you help us to do this? Or show us an example how to do? We tried to do this, but unfortunately without success.
Thanks for your help.
See the quick sample video attached Video Link : 5177
