As per the original Post
Hi
I was using Isodraw 7.0 from long time.
We have updated to Isodraw 7.3 and I have a problem enabling the cursor info in Isodraw 7.3 on windows 10.
"Use buffer drawing" option is not freed up.
I tried the below methods but was unsuccessful.
I tried to modify the "IsoDraw 7.3 Preferences" file in the local directory, but was unable to do so.
I closed all the open files and try to check the options, but still was unable to do so.
as per a suggestion, I even tried with a basic theme of windows, unsuccessful.
Even tried to reinstall, but 😞 .
Could you please help me to get rid of this problem.
Thanks in advance,
