We’re aware that the eSupport site is currently down, preventing community login. Our team is actively working on a fix and we’ll share updates as soon as possible.
is there a way to display the full value of an processing instruction. Were using processing instructions with many attributes and the arbortext editor prior 5.2 is displaying the full tag, but the newer versions cut them off and puts three points at the end. I have currently now clue how to activate this in some way?
thanks in advance for any ideas
Andreas
Andreas
The limitation doesn't seem to be applied to tags as you mentioned (checked in both 5.4 and 6.0). See the screenshot below
Andreas, can you provide a sample .xml, a screenshot with the current view and a screenshot with the desired view (from 5.2)?
Also, which version you're on now?
Dmitry, attached you´ll find the files with the pi´s. Before Arbortext editor 5.2 (5.1,5.0, 4.x) and from version 5.2 and above.
thanks
This restriction is set from PTC since version 5.2. All tags and pi´s are restricted to the length of 128 signs. This is hard coded, so currently nothing can be changed on this problem. A solution might an improvement from PTC.
Andreas
sorry but maybe you got a different version?
I tested it with Arbortext Editor 6.0 and the tag was cut off after an amout of chars. See the attached screen.
Also I received the answer from ptc, so I hope they know their code 😃
regards,
andreas
See the attached screens
You're using a custom DTD - could this affect the behaviour?
Did you try with DITA or Docbook documents?
No I didn't tried it with DITA or Docbook documents, cause we don't use them. We use a xml schema, but not with a dtd. I don't know if you can make such a restriction with a dtd? A dtd should not affect the internal handling of tags for the editor?
Andreas, can you try to open the sample DITA Topic (attached to the post) I used when making my screenshot in Editor 5.4 and/or 6.0? Does the tag gets cut on your installation?
If it does, this means that "cutting off" is not hardcoded and somehow dependent on the installation (since it doesn't on my side). With this information, you can ask your PTC contact to think again - there is defeinitely a way to disable "cutting off" for tags. Maybe there is one for disable for PIs as well?
If it doesn't, this means that "cutting off" is somehow dependent on DTD/Schema and/or doctype configuration (at least for tags. Unclear regarding PIs).
I opened and I got the same result as you. The tags won´t cut off as you mentioned. I will contact ptc as you suggest and link them to this discussion. Maybee its only for special documents restricted.
Thanks a lot for your work and investigation!!!
Andreas,
this is quite a while after you posted your last comment on this, but ...
is there a chance that PTC cleared up the confusion about PI length ?
I am using a xml dtd and I am down to where I am suspecting some dtd declaration file to mess up my unfortunately very lengthy PI's.
Not that I am using an declaration file but the catalog path always imports many more files then I care for.
I am on version 5.3 m080
Any wise words before I will have to run some external code first before I can edit the XML files ?
Sincerely
Sabine Thurston
Andreas,
Sincerely
Sabine Thurston
Andreas,
Sincerely
Sabine Thurston
Andreas,
Sincerely
Sabine Thurston
