dxf import into IsoDraw
bfriesen
18-Opal
We are moving to importing dxf files into Isodraw for line drawings. Is there a way that I can specify that a text layer in the dxf gets imported onto a layer labeled text in my IsoDraw template? or does this need to be done via a macro after the dxf has been placed in the file?
Bryon
mbalko
2-Explorer
(To:bfriesen)
Hi, the only (and best) way what I know is to do that with a macro ...
So you place the dxf, then run a macro against it to create the layers and move the different items onto them?
Bryon
mbalko
2-Explorer
(To:bfriesen)
I do not do that because I don not need it ... but I would do it this way if needed ...
Hmm ok, then I will need to research how this could be possibley done. thank you for the suggestion.
Bryon
mbalko
2-Explorer
(To:bfriesen)
it is easy ... something like that ...
Macro test
Select all
Activate layer "Rest"
Selected Elements to active layer
Activate layer "Text"
Selected Text to active layer
Select none
End Macro
