We have a customized stylesheet. I am trying to find out where the generated text is coming from in the footer. I need to remove the word part#. How do I tell what tab I need to look at. Is it an element, property set..?
I found the part# ref and went through every page and removed it from instance where I found it. My problem is it still shows up on my TOC. How do I find out where the TOC page is being generated from. I did modify contents pages, but it does not seem to correct my issue.
Bryon
Thank you all for the responses, I have found the text entries and have removed them.
