generating RTF from SGML instance
Level 1
>Hi adepters,
>I'm not sure if this topic has been discussed earlier (I haven't found
>emails about this issue):
>Has anybody ever tried to export/convert SGML instances to RTF?
>All ideas are welcome...
>Sandra
Hello Sandra!
There are other solutions but you must convert to XML first and do a bit(?) of
Tags (2)
Hi adepters,
I'm not sure if this topic has been discussed earlier (I haven't found emails about this issue):
Sandra
Sandra Rudolph SPX Valley Forge T.I.S.
Tel.: +49 (0)89 32671-247 Gutenbergstrasse 25
Fax: +49 (0)89 32671-400 85748 Garching b. Munich
e-mail: srudolph@vftis.com Germany
________________________________________________
A simple solution:
go from SGML to HTML (see if standard migration tools work) and then use
free HTML2RTF software or import your HTML in Word and create RTF.
A better solution is to use a tool like Omnimark and have full controll over
how your SGML is to be represented in RTF.
Success,
Martin Mollema
Have you investigated Jade (at http://www.jclark.com/). It is a DSSSL
formatting engine. One of the output media is RTF. The downside is that you
have to learn how to create DSSSL stylesheets.
If you know RTF and want total control over your output, you can opt to do a
conversion program in Perl or some other powerful string processing
language.
>Hi adepters,
>Sandra
Hello Sandra!
