getting change bars to show in a pdf
ptc-2919284
Looking for help on getting change bars to show in a pdf.
Have you read "Supporting Change Marks" in the Arbortext help? It's "help 382".
Dave Hintz
Siemens
Yes, and it was helpful but even though I've identified the element tags that enclose the change and code the FOSI for showing the change bar it still does not show in the pdf.
Tracy
Well, what's described in the help should be everything you need. Maybe if you post what you have in your FOSI and a sample of the markup that triggers the change bars we can help.
