goto_oid and current_tag_attr_value()
ptc-1123085
Hello. I am trying to get attribute values within a certain block of tags.
<relationship-block>
<form10k><form10kcomponent val="10k-business"/"></form10k>
<proxystmt><proxystmtcomponent val="prx-MERGERS"/"></proxystmt>
<forms1><forms1component val="s1-part1"/"></forms1>
<forms4><forms4component val="s4-part1"/"></forms4>
<form10><form10component val="10-other"/"></form10>
</relationship-block>
When the cursor is to the right of one of the empty tags with the ‘val’ attribute and I type this on the command line
response(current_tag_attr_value(val))
the Response dialog displays what I’m looking for. But if I put the same code in an ACL function, the Response dialog is empty.
function process_elements() {
$oid_marker = oid_root()
while (oid_valid($oid_marker)) {
$next_oid_marker = oid_forward($oid_marker)
# response(oid_name($oid_marker))
$oid_marker = $next_oid_marker
goto_oid($oid_marker)
response(current_tag_attr_value(val));
Is there something I am missing here? I want to transform all of the contents of val attributes within <relationship-block> tags to lowercase.
Thank you for any help in this matter.
- karen dL.
Karen Garrett de Luna
senior software engineer
Thomson Reuters
212.807.2936
Hi Karen-
Yes, you are missing something-quotation marks. J
While you can often get away with specifying unquoted strings on the command
line, it doesn't work in scripts. Try changing
to:
response(current_tag_attr_value("val"))
in your script and see if that works. Of course, you should also be able to
use a variable there, e.g.
$target_attr = "val";
response(current_tag_attr_value($target_arr));
should also work.
(BTW, if you copy and paste code from this message, replace the
Outlook-munged curly quotes with standard straight quotes before you run
it.)
HTH
--Clay
Thank you! I was going crazy trying to get this to work.
- karen dL.
