how to configure the publishing engine
erodriguez-5
Need to know how to configure PE from the tools/preference/Publishing Engine so that I can publish to PDF. What is the URL.  I've try a few and none work.  I'm new to Arbortext (as you can probably tell) so I need the simple solution.
The configuration of PE is documented in the Arbortext Help Center. Basically you need to know the URL of the PE server, and put that in to the dialog box. It is an http:// address that would be supplied by the person who setup the PE for you. Once you enter the URL, everything else "just works".
HI: To add on to what Gareth said typeically it looks some thing like this:
Http://(servername):8080/e3/servlet/e3  So you need to get the server name and the port is default to 8080 unless your admin changed it. Good luck.
