images quality
unknown1
images quality
The images of my documents are degraded in the EPIC
editor and when I print them.
The images format is JPG or SVG.
Do you have a solution to resolve this problem.
David GOPOIS
This message was checked by MailScan for WorkgroupMail.
www.workgroupmail.com
Hi David--
Are you printing directly to a printer, or to PDF via
Acrobat? If the latter, check your Acrobat Distiller/Adobe PDFprinter
settings to make sure it's not downsampling the images when it creates the PDF
file.
class=177330615-10022006>
--Clay
Sent: Friday, February 10, 2006
6:45 AM
To: Arbortext Adepters
Subject: images
quality
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">Hello,
degraded in the EPIC editor and when I print them.
SVG.
this problem.
style="FONT-WEIGHT: bold; FONT-SIZE: 10pt; FONT-FAMILY: Arial">
style="FONT-WEIGHT: bold; FONT-SIZE: 10pt; FONT-FAMILY: Arial">David
GOPOIS
style="FONT-SIZE: 12pt">
This message was
www.workgroupmail.com >> To unsubscribe from the
list, send an email to listmanager@maillist.arbortext.com with the following in
the body: unsubscribe adepters - For additional information on the adepters list
(how to subscribe or unsubscribe etc), send an email to:
listmanager@maillist.arbortext.com with the following in the body: info Adepters
- You may also go to forums.arbortext.com, enter the Adepters folder and change
your subscription options and preferences.>>
See Help 6229 for more details on SVG and the TIFF image resolution when
creating print output from Epic. By default, SVG is output at 300 dpi. Try
this:
set defaultprintdpi=600
If you're doing PDF via direct-to-PDF, you may need a passthrough
statement in your .pdfcf file. Graphic quality is pretty low if you use
the default screen.pdfcf found in [Epic-path]\lib. There are others there
more suited for print and press.
You may wish to modify the print.pdfcf or press.pdfcf with your own file
that can be stored in [Epic-path]\custom\lib. For example:
<images passthrough="JPG" |=" jpg=" |=" jpeg=" |=" jpeg=" |=" svg=" |=" svg=" |=" tif=" |=" tif=" |=" <br="/>TIFF | tiff">
Happy Friday all,
Jason
p.s. Absurd requests make life more exciting. Besides, they pay just as
well as all the other requests and make for wonderful conversations at
AUGI.
"Helberg, Clay" <chelberg@spss.com>
02/10/2006 08:10 AM
Please respond to
<adepters@arbortext.com>
To
cc
Subject
