import question 2: lots of spaces around a LINK basic mapping element
naglists
I am using Import to process FrameMaker MIF files. The cross-references are
preprocessed into the ppXML as <link> elements. My final XML output has 22
spaces before and after the output element (<fm_link>) and 26 just inside
the opening of fm_link.
There are no such spaces in the source or the ppXML.
The full set of ppXML tags associated with one instance looks something like
this:
<paragraph style="bu" ...="><link ...="><specialtext style="bold"&lt;br"/>...>sometext</specialtext></link>moretext</paragraph>
I have omitted most of the attribute values for clarity. My MapObjects for
bu and SPECIALTEXT/@emphasis-bold are unremarkable and don't produce any
unexpected behavior anywhere else.
Has anyone seen this behavior before?
Paul Nagai
It's like talking to myself.
MapTemplate Properties > Configure Output Encoding, Namespaces, and
Validation Options > More MapObject Options > Output Formatting tab. Clear
the checkbox for Indent XML. (Turn off pretty printing.)
Don't feel bad, I've done this a lot (typed out a question only to
realize the answer when I read it back).
I've actually typed emails to adepters I had never intended to send,
just to see if I could explain it to myself in a way that would make the
solution stand out.
It's the weirdest thing, but it works surprisingly well...
-Jason
Yes indeed, this is one of the best debugging methods. Explain your code
to someone else, and you often discover the source of the problem as a
result of organizing your thoughts for the explanation.
--Clay
It has to do with cognition. We use a different part of the brain explaining something vs. thinking through it in the problem space. I read about research where subjects were actually able to solve complex problems better when they explained it verbally to a teddy bear sitting on their desk.
I can't find a reference to it; maybe have to check in with my sasquatch contacts.
