John, thank you. I may not have explained this well. This is not a customization (or change by us). Fresh installs does this.
The editor when making edits near the bottom adjusts or autoscrolls to the center of the window (to be helpful). You eye is focused on the bottom of the window and make an edit, bam, it moves the scroll bars to have your edits now in the center of the window. After the auto scroll, I find I have to reorient myself. It is a bother. I recall that is was configurable, but my searches do not return anything, because I do not know how to describe it to have good search results.
Douglas
On 7/27/06, Dreystadt, John <-> wrote:Is it possible that you have a customization in your system that is
listening to the caret_moved callback and doing some processing? That is
the main thing I have seen that will cause the behavior you are seeing.
John Dreystadt
Software Development Director
Arbortext - PTC
734-327-6079
