macro to export cgm to users pictures folder
bfriesen
18-Opal
What does the code need to look like? Folder location would be C:\users\username\pictures\, how does it change for each individual user as the username changes.
Macro export CGM to user pictures folder
# recorded with Arbortext IsoDraw 7.3
  app.interaction=false
  Save
  Define final2 as string
    final2="X:\Photos\" + stripext(activedoc.name) + ".jpg"
    Export final2 "JPEG"
  app.interaction=true
  Save
  Define final as string
    final="C:\users\username\pictures\" + stripext(activedoc.name) + ".cgm"
    Export final "cgm"
End Macro
Bryon
Check to ensure you have a C:\temp folder on your computer. It's pretty standard but...
This is also assuming you used macro exactly. If not, please post the contents of your macro.
If I understand, you want the following line to vary depending on who is running the macro. Correct?
If I'm understanding, I do not believe there is a way to capture the user name. There is a 'system' type command.
Try this as an alternative. Hopefully the comments all make sense.
Macro myExports
    #Define variables.
    Define JPGLocal as string
    Define CGMLocal as string
    Define fileName as string
    Define CMDLocal as string
    Define tempLocal as string
    Define tempCGM as string
    #Define cmd.exe.
    CMDLocal = "C:\WINDOWS\system32\cmd.exe"
    #Define local temp Local.
    tempLocal = "C:\temp\"
    #Turn off possible error/warning prompts during export.
    #Save file to current Local.
    Save
    #Define variable for file name
    fileName = stripext(activedoc.name)
    #Set export Local for jpg.
    JPGLocal="X:\Photos\" + fileName + ".jpg"
    #Export jpg.
        Export JPGLocal "JPEG"
        #Set temp CGM export path.
        tempCGM = tempLocal + filename + ".cgm"
        #Set final cgm Local using cmd format (%variables%).
    CGMLocal = "%userprofile%\pictures\" + stripext(activedoc.name) + ".cgm"
    #Export CGM to temporary location.
        Export tempCGM "CGM"
        #Calls a cmd window and runs a move command to move the file to the final location.
        Launch CMDLocal "/c move /Y " + tempCGM + " " + CGMLocal
        #Turns prompts on.
End Macro
Thanks Trevor, I am getting an error log that states
MacDon_macros.ismexport CGM to User Pictures folder
The file '%ls' is not open. "Export tempCGM "CGM""
Bryon
Thanks for the help. I did not have a temp folder at that location. But it seems to work as expected now that I do.
Thanks for your expertise and help. It is much appreciated.
Bryon
