What does the code need to look like? Folder location would be C:\users\username\pictures\, how does it change for each individual user as the username changes.
Macro export CGM to user pictures folder
# recorded with Arbortext IsoDraw 7.3
app.interaction=false
Save
Define final2 as string
final2="X:\Photos\" + stripext(activedoc.name) + ".jpg"
Export final2 "JPEG"
app.interaction=true
Save
Define final as string
final="C:\users\username\pictures\" + stripext(activedoc.name) + ".cgm"
Export final "cgm"
End Macro
Bryon
Check to ensure you have a C:\temp folder on your computer. It's pretty standard but...
This is also assuming you used macro exactly. If not, please post the contents of your macro.
If I understand, you want the following line to vary depending on who is running the macro. Correct?
If I'm understanding, I do not believe there is a way to capture the user name. There is a 'system' type command.
Try this as an alternative. Hopefully the comments all make sense.
Macro myExports
#Define variables.
Define JPGLocal as string
Define CGMLocal as string
Define fileName as string
Define CMDLocal as string
Define tempLocal as string
Define tempCGM as string
#Define cmd.exe.
CMDLocal = "C:\WINDOWS\system32\cmd.exe"
#Define local temp Local.
tempLocal = "C:\temp\"
#Turn off possible error/warning prompts during export.
#Save file to current Local.
Save
#Define variable for file name
fileName = stripext(activedoc.name)
#Set export Local for jpg.
JPGLocal="X:\Photos\" + fileName + ".jpg"
#Export jpg.
Export JPGLocal "JPEG"
#Set temp CGM export path.
tempCGM = tempLocal + filename + ".cgm"
#Set final cgm Local using cmd format (%variables%).
CGMLocal = "%userprofile%\pictures\" + stripext(activedoc.name) + ".cgm"
#Export CGM to temporary location.
Export tempCGM "CGM"
#Calls a cmd window and runs a move command to move the file to the final location.
Launch CMDLocal "/c move /Y " + tempCGM + " " + CGMLocal
#Turns prompts on.
End Macro
Thanks Trevor, I am getting an error log that states
| MacDon_macros.ism | export CGM to User Pictures folder | The file '%ls' is not open. "Export tempCGM "CGM"" |
Bryon
Thanks for the help. I did not have a temp folder at that location. But it seems to work as expected now that I do.
Thanks for your expertise and help. It is much appreciated.
Bryon
