menu to queue print jobs, need help modifing menu link
bfriesen
Trying to add the set preference to my queue menu, but it does not seem to work. Looking for some guidance in ACL.
# create menu
if (!menu_exists('.Window')) {
return;
if ( !menu_exists( '.Queue.' ) ) {
menu_add -menu .Window "Queue";
menu_add "Queue." ""Long" cmd "set -preference petransactionoptions = \"queueID:long\""";
menu_add "Queue." ""Short" cmd "set -preference petransactionoptions = \"queueID:short\""";
menu_add "Queue." ""None" cmd "set -preference petransactionoptions = \"queue:yes\""";
} # _addmenu()
BRyon
I'm a bit rusty myself but I think you are almost there. If it were me I'd simplify it down a little at least for initial testing to get it working? I added my version of this code at the bottom. I used the Help Center as a reference, I haven't tested this in Arbortext yet. BTW, in case you didn't know already you can use the response() command to test out if the -cmd is being called correctly. It will popup a dialog so you can see what it is about to do.
https://support.ptc.com/cs/help/arbortext_hc/ae61_hc/aeAcl/help9122.html
function addQueueMenu() {
  if ( !menu_exists( ".Queue." ) ) {
    menu_add .Queue. "Long" -cmd {set -preference petransactionoptions = "queueID:long"};
    menu_add .Queue. "Short" -cmd {set -preference petransactionoptions = "queueID:short"};
    menu_add .Queue. "None" -cmd {set -preference petransactionoptions = "queue:yes"};
add_hook("menuloadhook", "addQueueMenu");
Hi Bryon,
This is actually covered in the Arbortext Help Center but long story short you need to use menuloadhook() - see here: https://support.ptc.com/cs/help/arbortext_hc/ae61_hc/aeAcl/help796.html?queryId=173b1b3f891#ATI.759
-Gareth
Thanks for the info Gareth, I am not an ACL kind of guy, more of a hack and slash... or copy and paste...
Something like this?
function _addmenu() {
} # _addmenu()
# function: _menuloadhook()
function _menuloadhook(win,menupath) {
_addmenu();
} # _menuloadhook()
# function: _addhook()
function _addhook() {
add_hook('menuloadhook',package_name()."::_menuloadhook");
} # _addhook()
Bryon
Thank You Gareth, that works as expected.
Bryon
Just doing some clean up removed the  dot before Queue and added the ""
if ( !menu_exists( '.queue.' ) ) {
menu_add "Queue." "Long" -cmd {set -preference petransactionoptions = "queueID:long"};
menu_add "Queue." "Short" -cmd {set -preference petransactionoptions = "queueID:short"};
menu_add "Queue." "None" -cmd {set -preference petransactionoptions = "queue:yes"};
Thanks again Gareth
Bryon
